08-07-2021
14:08
14:21
08-07-2021
14:08
14:21
Lights will not turn on on the back of my Versa 2 will not connect to Bluetooth anymore saying it's updating and then says it can't update goes from 5% back down to a negative 1% and it's not working unable to do anything from the app what is happening was working fine until this morning
08-07-2021 14:29 - edited 11-09-2023 10:54
@Croteau Thanks for the details provided in your previous post. I understand where your concern is coming from.
If your watch is stuck on the Fitbit Log, please make sure to follow the steps I provided above so the issue can be solved.
Hope that does the trick. 🙂
08-07-2021 14:23
08-07-2021 14:23
Hi there, @Croteau. Welcome to the Community Forums. Thanks for the details provided in your post.
May I know the model of your mobile phone? Please make sure it meets the requirements listed here.
Despite meeting the above requirements, the following devices often exhibit compatibility issues that cause our products and services to not operate properly:
If your phone is not on the list above and meets the requirements to operate properly with the Fitbit app, please try the steps below:
1. Remove the Versa 2 from your phone's Bluetooth settings and in the Fitbit app.
2. Restart your Versa 2.
3. Turn off other Bluetooth connections when not in use.
4. Plug it into the charging cable and open the Fitbit app.
5. Set up your Versa 2.
6. Update your Versa 2.
Hope that helps.
08-07-2021 14:25
08-07-2021 14:25
