06-29-2022
18:14
09:29
06-29-2022
18:14
09:29
My fit didn’t automatically changed time zone.
06-30-2022 09:30 - edited 07-12-2023 10:48
Hi there, @Vegalou. Welcome to the Community Forums. Thanks for the details provided in your post.
As @SunsetRunner has mentioned, please keep in mind that your Fitbit device may show an incorrect time if it hasn't synced or has been unpaired from your Fitbit account. Your Fitbit grabs the time of the device you're syncing with. To make sure your watch has recently synced, go to your Fitbit account, tap the Today tab > your profile picture > your device image.
If by any chance you are running into syncing issues, see Why won't my Fitbit device sync? or if you need to relink your watch, see How do I set up my Fitbit device?
Also, note that the time on your Fitbit device may be wrong after you travel to a different time zone or when clocks change for Daylight Savings. If you changed time zones and the time on your Inspire is still incorrect after syncing, make sure the time zone setting is correct. For more information, see How do I change the time on my Fitbit device?
If none of the above works for your, I recommend changing your time zone to a complete different one, sync your device, put the correct time and sync again.
06-29-2022 18:24
06-29-2022 18:24
Hello @Vegalou
Your time should be the same time as the mobile device you have your Versa 2 connected to on Bluetooth. Try syncing to see if that helps. If not open your Fitbit App, tap your profile picture and then scroll down and tap App Settings. Now tap time zone. Look to ensure your time zone is correct and set to automatically. Sync your Versa 2 if any changes are made. If you find the time zone was already correct turn automatically off, sync your Versa 2, turn automatically back on and sync your Versa 2 again. Now go back to App settings and this time tap location. Make sure it is also correct and set to automatically. If not again make the corrections then sync your Versa 2.
😃 Please let me know if this answered your question and repaired the time problem. Keep me posted
