04-12-2020 12:43
04-12-2020 12:43
Can't restart my versa 2 it turned off cant turn it back on keep getting...keep getting a red x in red circle with message..." data not cleared sync and try sgain". I hold the button down for 10 seconds..the fit bit logo comes up and the the same red message appears. What should I do?
04-17-2020 02:27
04-17-2020 02:27
I have had the exact same issue, tried all the recommended troubleshooting to no avail. Emailed customer support and got a response next day. Briefly ran through the steps I had taken and without any quibble offered a replacement which is now on its way. Hopefully better luck with the next one. I don't think this is an issue that can be resolved, so I say contact support. They are very helpful.
Good luck!
