08-22-2021 19:31 - last edited on 08-23-2021 11:14 by LiliyaFitbit
my titbit Versa 2 (I believe that's what it is) screen will not turn on at all but I know it still works because my alarms will still go off but I can't turn them off at all.
08-22-2021
21:00
09:01
08-22-2021
21:00
09:01
The screen may be faulty.
If this has just happened following a firmware update that is the reason.
However try a restart.
If that doesn't fix it you could try a factory reset but run the risk of it never working at all.
If it's still under warranty [2 years in most European countries] take it back for a new replacement or you can contact Fitbit Support directly. They may be able to help you further but you are unlikely to get a new one, though they are helpful and will talk you through a factory reset.
08-22-2021 21:14
08-22-2021 21:14
The restart will not work I have tried that and I have only had it for a year, but I am not sure if I have a warranty on it and even if I do, I would not know where to take it. Thank you for your response.
08-22-2021
21:20
08:35
08-22-2021
21:20
08:35
You take it back to where you bought it. They can't be repaired so can only be replaced.
Warranty comes with it, 1 or 2 years, depending on the country of purchase.
If thats not an option try Fitbit support, a factory reset might just work, as at this stage you have nothing much more to lose.
