03-20-2023 06:15
03-20-2023 06:15
My clock face was replaced and I can’t find the one I had. Nor can I find an analog replacement face.
03-20-2023 12:36
03-20-2023 12:36
Hi @MaryGeorge777 - just to make sure it's not a configuration problem - double tap the watch face and swipe it right to get to the Quick Settings screen and make sure that Always On is not enabled.
03-20-2023 13:09
03-20-2023 13:09
03-20-2023 13:14
03-20-2023 13:14
@MaryGeorge777- Presumably you pressed and held the clock face till the choice of clock faces came up, or looked in the Fitbit App Gallery tile.
It would be odd to just go missing unless you loaded several new ones in the Gallery tile or did a factory reset?
03-20-2023 17:11
03-20-2023 17:11
