08-10-2022
06:57
17:34
08-10-2022
06:57
17:34
I can able to connect versa 3 controls but under this there is one option "Calls" . I tried to enable this option over phone's Bluetooth but not able to enable(disable automatically). Is anyone facing this issue OR anyone knows how to enable Calls option.
08-11-2022 09:57
08-11-2022 09:57
Hi @DevanshuS.
Have you gone through the set-up process in the Fitbit mobile app?
Tap on your profile picture - tap on Versa 3 - scroll down to and tap on "on-wrist calls".
If you've already done this it might be worth going into your phones Bluetooth settings and un-pairing/forgetting Versa 3 controls from there and then trying the above steps once again.
Best Answer08-11-2022 17:36
08-11-2022 17:36
Yes I have done this "On Wrist Call" but not able to enable calls option under Versa 3 controls.... I think after enable, I can use fitbit speaker during call.
