03-22-2022
20:24
20:17
03-22-2022
20:24
20:17
I have restarted my phone. I have uninstalled the the app and reinstall it. I have unpaired and repaired Versa 3.
I am getting call notifications but not text. I have swapped from default to Textra and back, still receiving the same message. Any ideas on this issue?
03-23-2022 11:07
03-23-2022 11:07
Hi, welcome to the Fitbit Community forums, @Tsukino.
Thank you for the information provided regarding the inconvenience you found with your Versa 3.
Before taking any other options into consideration, please make sure that you've tried the steps listed in this article, as they have been helpful for other users experiencing something similar, and you can also try to disabling the notifications completely and setting them up again.
In addition, please check that the Do Not Disturb Mode and the Sleep Mode options are not activated, as they prevent the watch from vibrating and receiving notifications.
If you're still having the same problem, other users have also found the steps below helpful:
You can find other useful tips for using the Fitbit app on Android devices here.
I'll be around.
03-23-2022 11:07
03-23-2022 11:07
I'll be around.
03-26-2022 19:38 - edited 03-26-2022 19:38
I am not sure what fixed it, possibly the power settings. But after turning off the power saving ability on Android and turning it back on, followed by a reboot, it allows notifications to work again.
04-07-2022 13:00
