03-16-2022
08:10
20:17
03-16-2022
08:10
20:17
The Alarms on my Versa 3 stopped working after the time change for Daylight Savings last weekend. I can program it for a certain time but it just doesn’t go off. Has anyone else had this problem? Would love some help.
03-19-2022 06:02
03-19-2022 06:02
@Mullyj19 We‘re taking your comments and sentiments in regards to our products into consideration.
If you haven't done so yet, please try removing the Bluetooth connection between your phone and your Fitbit device:
*On your phone, tap Settings > Bluetooth > the information icon next to the name of your Fitbit device > Forget This Device.
*Open the Fitbit app and set up the connection again. You should receive a message asking you to allow your Fitbit device to pair with your phone. Tap Pair to approve the request.
Sync your Versa 3 automatically when you open the Fitbit app or manually by tapping your profile picture > your device tile > Sync Now.
If the issue persists, please see Why won't my Fitbit device sync?
See you around.
03-18-2022 03:43
03-18-2022 03:43
I can’t set the alarm on my versa 3 - it reverts back to the current time as my alarm time the next day.
03-18-2022 06:26
03-18-2022 06:26
Hi there, @bufsher @Mullyj19. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with the silent alarms on your Versa 3. I understand where your concern is coming from.
Please try removing the alarm and then adding it once again. You can find instructions on how to remove alarms by clicking here. Basically what you want to do is:
Then they should start working. Please give it a try and let me know how it goes, I'll be glad to continue assisting you.
Also, keep in mind that If you're using Smart Wake, that would explain why the alarm is going off before the schedule time. Smart Wake attempts to find the best time to wake you starting 30 minutes before the alarm time you set. It avoids waking you during deep sleep so you're more likely to wake up feeling refreshed. If Smart Wake can’t find the best time to wake you, your alarm alerts you at the set time. For more information, see How do I manage alarms on my Fitbit device?
Hope this helps.
03-19-2022 02:03
03-19-2022 02:03
03-19-2022 06:02
03-19-2022 06:02
See you around.
03-12-2023 04:51
03-12-2023 04:51
This has been going on for years also with versa 2 now with versa 3 Fitbit refuses to fix this glitch I have no understanding why .It’s been happening to me for years now since I bought Versa 2 The day after time change the alarm just doesn’t go off really bugs me they have never fixed it.The fix’s here don’t work it happens again like clock work.Total BS.
