01-19-2022
05:43
20:34
01-19-2022
05:43
20:34
I have a new Fitbit Versa3 and the face of my watch often goes to a Spotify notification. "Connect to a device, start Spotify on another device and it will appear here". How can I remove this? Spotify is set up and there aren't any issues but I don't want this default to constantly be on my watch when it wakes up.
01-20-2022 06:19 - edited 11-13-2023 11:18
Hi there, @Pauletterj1 . Welcome to the Community Forums.
As @Guy_ has mentioned, please keep in mind that you can replace the Spotify shortcut for any other option. To do so, open the Settings app on your watch and tap Shortcuts. In the Double Press section, tap the shortcut you want to change. Swipe right to return to the previous screen. For more information, see How do I navigate my Fitbit device?
Hope that helps.
Best Answer01-19-2022 09:14
01-19-2022 09:14
HI @Pauletterj1 - you probably assigned the Spotify App to your long button press action in the Watch Settings. Go in and change it to something else.
Note: if you use Music Controls [often assigned to double press shortcut] you can control your music on the phone and still run your Clock or App without having to stop them.
Best Answer01-20-2022 06:19 - edited 11-13-2023 11:18
Hope that helps.
