06-29-2023
09:17
11:55
AndreaFitbit
06-29-2023
09:17
11:55
AndreaFitbit
I had my versa 3 charging during dinner then put it on before i went to bed and it was completely dead by morning, I normally get 7 hours of sleep so it didnt even last 8 hours during my sleep.
06-30-2023 12:05
06-30-2023 12:05
Welcome to the Fitbit Community, @Skeeve_NL. I'm sorry to hear that your Versa 3 battery drains fast.
Please check: Can I extend my Fitbit device's battery life? How hot does your device get?
Thank you for your suggestion @Guy_.
06-29-2023 11:44
06-29-2023 11:44
Hi @Skeeve_NL - it may not have charged properly, see How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
If it is charging and gets hot while charging stop immediately, the watch has an internal fault, most commonly caused by water ingression which causes rapid battery drain.
Rapid drain can be other things see How to resolve the Major issues causing short battery life.
06-29-2023 11:57
06-29-2023 11:57
There doesnt seem to be an issue with the charging, the versa 3 it self gets a little warm.
06-30-2023 12:05
06-30-2023 12:05
