10-01-2022
00:03
17:09
10-01-2022
00:03
17:09
I’ve had my fit bit for a month, the first 2 weeks the battery was great but now I’m lucky if it lasts 24 hours , does anyone have any advice please?
10-01-2022 10:19
10-01-2022 10:19
Hi there, @MRL68. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 3. I understand where your concern is coming from.
By any chance, are you're using Snore Detection? If so, please note that the Snore Detection feature does impact your device’s battery, so we recommend charging your device to at least 40% before going to bed. For more information, see How can I use my Fitbit device to detect snoring and noise levels while I sleep?
Also, please bear in mind that battery life will depend on how frequent certain features are used in general. Because you're using an Always-On Display clock face, I'd recommend changing the clock face to another one made by Fitbit and monitor your it's behavior in the next day. Additionally, try turning off this setting by opening the Settings app on your watch > Display > Always-on display.
Hope this helps.
10-03-2022 18:09
10-03-2022 18:09
Having the same issue.
10-03-2022 18:55
10-03-2022 18:55
Same issue. Battery drains in one day.
