01-29-2022
23:38
20:34
01-29-2022
23:38
20:34
After charging the battery to 100%, the battery gets drained the next time when i switch the device inside a day. Any solution?
01-31-2022 04:05 - edited 08-08-2023 12:00
Hi there, @shalinpradeep. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 3.
How are you charging your Versa 3? Please check below some tips for charging your Versa 3 properly:
As with other electronic devices, the battery will depend on the features and how often they're used, such as the GPS, Spotify app or the Always-On display. While this doesn't mean that you shouldn't use them, please take into into consideration the conditions that impact your watch's battery.
That being said, I'd recommend to change the clock face to one designed by Fitbit and please confirm if you've followed the tips and recommendations to maximize your watch's battery life described here.
03:23
10:21
01-30-2022
03:23
10:21
Hi @shalinpradeep - firstly make sure the watch did charge to 100% by swiping the face to the right to get to Quick Settings.
Then make adjustments and remove all the features temporarily from the list How to resolve the Major issues causing short battery life.
Once you have a good battery enable those you need and monitor.
Best Answer01-31-2022 04:05 - edited 08-08-2023 12:00
