Versa 3 battery drains in one day
ANSWERED
After charging the battery to 100%, the battery gets drained the next time when i switch the device inside a day. Any solution?
1 BEST ANSWER
Accepted Solutions
Hi there, @shalinpradeep. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 3.
How are you charging your Versa 3? Please check below some tips for charging your Versa 3 properly:
  • Make sure there are no metal objects, such as jewelry, nearby as your device charges. After your device is charged, unplug the charging cable.
  • Keep the charging contacts on the back your device and the pins on the charging cable clean and free of debris. For more information, see How do I clean my Fitbit device?
  • For best results, don’t leave your device plugged in on the charger longer than overnight.
As with other electronic devices, the battery will depend on the features and how often they're used, such as the GPS, Spotify app or the Always-On display. While this doesn't mean that you shouldn't use them, please take into into consideration the conditions that impact your watch's battery.
That being said, I'd recommend to change the clock face to one designed by Fitbit and please confirm if you've followed the tips and recommendations to maximize your watch's battery life described here.
2 REPLIES 2
Hi @shalinpradeep  -  firstly make sure the watch did charge to 100% by swiping the face to the right to get to Quick Settings.
Then make adjustments and remove all the features temporarily from the list How to resolve the Major issues causing short battery life.
Once you have a good battery enable those you need and monitor.
