06-03-2023
16:59
09:19
06-03-2023
16:59
09:19
I have been using my Versa 3 for 15 months and I like it. When the watch is on and off-wrist, it can keep the charge for up to six days but when I turn it off it rapidly discharges in two days.
Please let me know if you have a similar experience or any solution.
06-03-2023 21:11
06-03-2023 21:11
Hi @Saman65 - that is odd behaviour for a watch but a rapid discharge especially if you did a full shutdown would indicate internal damage possibly from water getting in.
It could be the moisture is causing a short circuit inside depending on the position the watch is in when shutdown but ultimately will cause internal damage in every position.
If it gets hot while charging stop immediately and if it develops other odd symptoms it would confirm an internal problem.
06-03-2023 21:44
06-03-2023 21:44
06-03-2023 21:52 - edited 06-04-2023 00:17
06-09-2023 16:06 - edited 06-09-2023 16:12
Let me give you a report to see how fast my Versa 3 watch is discharged. I charged my watch to 100% on June 7th 20h20. When I turned it on on June 9th at 15h22, its charge was 18% in less than two days! But when it is on and not on-wrist, the charge will endure 5 days!
It is really strange and I think that when the watch is shut down it activates all of the features and consumes electricity more than on mode.
The watch seems normal in other situations and does not get hot at all.
