Versa 3 battery drains when it's shut down
When my Versa 3 is on, it can hold a charge for up to six days. But when I turn it off, it is completely discharged in less than two days!!!
Does anyone have an idea?
3 REPLIES 3
Hi there, @Saman65. It's nice to see you around the Fitbit Community Forums. Thanks for bringing this situation to my attention.
To better assist you, may I know if this is the first time you notice this behavior? Have you tried shutting down your Versa 3 a couple of times to see if the battery drains every time it's turned off?
Meanwhile, I'd recommend restarting your Versa 3 by following these steps. Also, please take a look at this help article Why isn't my Fitbit device's battery charging?
I have been using my Versa 3 for 16 months and It has been like this as long as I remember.
But it is now OK! I turned it off five days ago and today I checked its charge which was 95%. So it discharged 5% in give days.
Do you think if there had been a glitch or a short circuit by water?
Anyway it seems that the problem is fixed at the moment
@Saman65 I'm glad to hear your Versa 3 seems to be ok now.
Regarding your question, we are not sure what might have caused this, but we would expect this to be one glitch and I would ask you to keep an eye on your watch, and in the case this happens again, please let me know and I will be glad to further investigate.
