Versa 3 battery drains within 20 hours
Oh GEEZ, I'm sorry. I didn't realize I posted it in SDK area.  My bad!  Yes, if you can move it, I would certainly be grateful.
Moderator edit: clarified subject.
8 REPLIES 8
The recent fitbit update on my Versa 3 has drained my battery within 24 hours which used to last 5-6 days is easily. I've already had my settings reduced to save on battery usage.  I've seen complains on the Versa 3 start back in Jan 2025.  Is there going to be a fix for this, Google/Fitbit?? Is this being looked into? It is totally unusable now.  I already signed up for the $50 consolation prize. Is this Google's way of pushing us to buy a new fitbit??
If it's the SDK causing this, make sure you disconnect the developer bridge when you're not debugging.
Peter McLennan
Gondwana Software
Thank you for your comment. I'm not using the SDK developer bridge.  It is not connected.
Are you sure it's an SDK issue?
Peter McLennan
Gondwana Software
I don't know why you are asking about the SDK issue. There is no mention of SDK in my initial post.
You posted in the 'SDK Development' forum. If you like, I can try to move this thread to the Versa 3 forum.
Peter McLennan
Gondwana Software
No worries. Hang on; this could be a rough ride.
Peter McLennan
Gondwana Software
LOL, thank you! 🙂
