Versa 3 battery indicator hasn't moved from 99% charge
Did the update 3 days ago. Watch is working OK, but the battery indicator hasn't moved from 99% charge. Has anyone share experienced this?
Moderator edit: clarified subject.
5 REPLIES 5
Welcome to the forums @Lm551
Thank you for providing the information regarding your Versa 3.
I haven't experienced this same situation on my Versa 3. However, I'd suggest you try to restart the device as indicated here: How do I restart my Fitbit device?
thanks but no, that didn't work
Mine hasn’t moved from 100% in 2 days.
thanks Manu. The restart didn't appear to work initially, but after about 6 hours the battery indicator has started to change
I restarted mine 4 times doing the day, still at 99%.
