03-15-2022
06:30
20:21
03-15-2022
06:30
20:21
I just purchased and received my Versa 3. I’ve had it a few days and noticed that at night time when I charge it it’s at 100% yeah by the morning it’s at 68%.
Anything I should be doing?
03-15-2022 12:13 - edited 11-26-2023 16:47
Hi there, @JRLEDGER. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 3.
Are you using Snore Detection? If so, please note that the Snore Detection feature does impact your device’s battery, so we recommend charging your device to at least 40% before going to bed. For more information, see How can I use my Fitbit device to detect snoring and noise levels while I sleep?
However, I'd like to share with you that the battery life will depend on how frequent certain features are used in general. Because you're using an Always-On Display clock face, I'd recommend changing the clock face to another one made by Fitbit and monitor your it's behavior in the next day. Additionally, try turning off this setting by opening the Settings app on your watch > Display > Always-on display.
Hope this helps.
Hope this helps.
