01-02-2023
16:06
12:08
01-02-2023
16:06
12:08
My Versa3 battery is draining overnight when the watch has been turned off.
01-06-2023 12:11 - edited 09-26-2023 04:19
Hello there, @Treetop55. Thanks for stopping by in the Community Forums and sharing the details about the issue with your Versa 3.
While reading your post I was wondering if you manually turn off your Versa 3?
Nevertheless, since the battery is draining overnight, I'd like to ask if by any chance you're using snore detection? Please note that the Snore Detection feature does impact your device’s battery, so we recommend charging your device to at least 40% before going to bed. For more information, see How can I use my Fitbit device to detect snoring and noise levels while I sleep?
However, I'd like to share with you that the battery life will depend on how frequent certain features are used in general. Because you're using an Always-On Display clock face, I'd recommend changing the clock face to another one made by Fitbit and monitor your it's behavior in the next day. Additionally, try turning off this setting by opening the Settings app on your watch > Display > Always-on display.
01-06-2023 12:30
01-06-2023 12:30
Best Answer01-07-2023 07:20
01-07-2023 07:20
@Treetop55 You're very welcome! I'll be around if you need anything else. 🙂
