Versa 3 battery stuck on 100% since Tuesday
So updated the mandatory firmware on my Versa 4 on Tuesday, it is now showing 100% battery on both the app and device on Thursday evening. Is this a bug of the firmware as I don’t know when to charge it now
6 REPLIES 6
Hi there, @Davieboy79. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention. I understand your concern, I will do my best to help you with this!
I'd suggest waiting a couple of days more to see if the battery percentage drops. If the battery keeps stuck on 100%, please try restarting your Versa 3 by following these steps
I am having the same problem with the fitbit versa 3 updated the firmware yesterday 15 hours later still showing 100%
Hi @Davieboy79  @Mike6624 - this seems to be a bug in the [perhaps rushed] new firmware 44.128.6.21  - details found here,
The latest level is normally 44.128.6.17 and shouldn't have that problem.
still not working correctly i restarted my Fitbit versa 3 as instructed and the battery level went down to 99% , 24 hours later it is still at 99% . the new firmware has caused this . when will Fitbit fix it . not knowing how much charge is left makes it pretty useless .
So I restarted my device once,  the battery percentage dropped to 99% and remained there for around 5 hours. Restarted the device again and then it dropped to 98%.
After another 24 hours i restarted again and now it seem to be working as expected.
i did the same , but only started working correctly when i turned the Fitbit versa off and then back on again , so at least its now working correctly .
