Versa 3 battery symbol is red
My battery symbol is outlined in red!  Have Versa 3.  What does this mean?
2 REPLIES 2
Hey Mama Jeanny, it looks like your Versa 3 has a lot of need for electricity. So get it on the charger and look at your Versa screen to see it change.
Your fitbit app will also tell you how high or low your battery load is. (Top of the screen on the right)
And you can set in the app that you need a notice when the battery is low. (below 25%)
Kepp your battery above 20%. I charge it every day when going to the shower and dress up. Takes me 20 minutes or less. My watch is mostly between 80% and 30%
Community Council MemberMario Dings | Rotterdam NL
Fitbit: Versa, Versa2, Sense. (Versa light) - Phone: Android. - Developer clockfaces.(Nederlands)
Hi @MamaBear1949  - in addition to what @MarioDings says, if you swipe your watch face to the right to get to Quick Settings you will see the current battery level on the watch, if your normal face doesn't show it.
Also if you use a clock face, such as SimpleClockPro, it will show you battery level and remind you constantly when it needs charging below 17%, each time the level falls 1%. So you won't miss the need to charge.
