Versa 3 - battery won’t charge
My Versa 3 is around 18 months old - it’s been great !  However while we were on holiday it refused to charge.  I waited until I got back to try other chargers, adapters and sockets.  Not sure what else I can try but it is still not working.  Any advice appreciated.  JB
5 REPLIES 5
I have the same problem with mine. When I left for work this morning it was 100% and at 12:00pm it is 32%. Sitting at my desk most of the day so should not be this low. Doesn't make it through the whole day. I have to have a charger at my desk to keep it going.
Hi there!
A warm welcome to the Fitbit Community! It's great to see you here.
Thank you so much for letting us know about this situation and for all your efforts.
@Ju_Bolton I recommend you follow all the tips described in this article: Why isn't my Fitbit device's battery charging?
@thiamarie Can you please check if your Versa 3 has a firmware update pending? You can try to follow these instructions: How do I update my Fitbit device? As the battery is draining way too fast you can try to follow these tips too: Can I extend my Fitbit device's battery life?
Hi there - thank you for responding to my post.
I have cleaned the contacts on the watch and the pins on the charging wire - still won’t charge.  I have tried plugging the USB into several different ports - both directly and via an adapter- still won’t charge. Also left it plugged in overnight. No success.
Any other things to try?
Julia Bolton
Hi there @Ju_Bolton
Thank you so much for all your efforts and for your answer.
Since you have tried the steps and your Versa 3 still doesn't work, I need more information from you, which is best shared privately. I am sharing a link to a form for you to fill out here.
This form is for you only, so let me know when you have completed it.
Hi
Form completed and sent.
Looking forward to hearing from you.
Ju_Bolton
