08-29-2022
17:10
17:17
08-29-2022
17:10
17:17
I bought a Versa 3 a few days ago. The sleep tracking worked the first 2 nights but I hasn’t updated for last night. The app shows that it was tracking my HR last night, so why don’t I have a sleep score? I’ve tried restarting but made no difference
08-30-2022 07:23
08-30-2022 07:23
Hi there, @Slan86. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 3 before reaching out.
I've seen you contacted our Support Team after posting here and they've already assisted you. If you still need help or have any questions/concerns regarding the outcome of your case, please feel free to contact our team back for further assistance.
See you around.
Best Answer08-30-2022 13:14
08-30-2022 13:14
Hi MarreFitbit. So I have a similar problem. Just went from a charge 3 to a Versa 3. I find 90% of the time it does not track my sleep at all. What it will do is track my last two hours of sleep. Often just prior to the alarm going off, I wake up to go to the bathroom and then fall back asleep again for 2 more hours. The Fitbit will track these last two hours, but not the 6 hours of sleep I had prior.
Any suggestions on how to correct this issue?
Best Answer08-30-2022 13:17
08-30-2022 13:17
Also having problems. Versa 3 not tracking sleep for 6 weeks now. I have tried every suggestion on various forums but nothing works.
Also noticed calories not calculating accurately either..
Best Answer08-31-2022 05:23 - edited 08-15-2025 12:34
Hi there, @therealmramx @LcDo. Welcome to the Community Forums. Thanks for the details provided in your post and also trying to troubleshoot this issue before reaching out. I understand where your concerns are coming from.
To better assist you, please make sure that you've taken in consideration the following in order to get sleep stages:
For more information, see What should I know about Fitbit sleep stages?
Additionally, I'd recommend to sync your Fitbit devices to the app after waking up. This will help to make sure that all your data is sync properly.
Also, note that your time asleep is calculated by subtracting your time spent awake and restless from your overall tracked sleep time. For example, if you slept 8 hours but woke up 2 times for 15 minutes each, your time asleep would be 7 hr 30 min.
Hope this helps.
Best Answer08-31-2022 05:49
08-31-2022 05:49
Hi MarreFitbit,
Thanks for responding
Unfortunately, I have tried all of the above suggestions on a number of occasions over the last six weeks none of which resolved the issue. I have also done numerous factory resets and uninstalled and set up from scratch again to no avail.
Regards,
LcDo
Best Answer09-01-2022 07:14 - edited 08-15-2025 12:18
@LcDo I appreciate you had followed the tips and recommendations provided above.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
Best Answer09-10-2022 16:45
09-10-2022 16:45
Hi Marre,
Could you please share the solution as my versa3 hasn't tracked sleep for 6 weeks..I have tried everything I found on various forums. Nothing works. Also noted that the calorie tracker is way off..
Thanks
