05-28-2025 13:24
05-28-2025 13:24
Is there any way I can still see my activity after during recording my versa 3 turned off due to low battery ?
it should at least still record until the moment it turned off right?
05-30-2025 07:42
05-30-2025 07:42
Hello @Sandrabg and welcome to the Community. I apologize if I misread what you wrote. It sounds like you wrote that you are using the Exercise app and your battery died before you were able to end the workout. When you finish and check done, there is code that runs that ends the workout and saves the specific data. It can't save the data if it doesn't follow those steps.
If this doesn't answer your question, can you ask it a different way?
Laurie | Maryland
Best Answer05-30-2025 07:49
05-30-2025 07:49
Hi there,
thank you for your writing:)
indeed I was using the training alp from my versa 3 in order to record the 30 km I was cycling but since there were pauses in between and the total time was like 5 hours.. at the end my versa turned off due to low battery and did not manage to click on the option finish workout…
my training app is linked to my strava account (training app) but unfortunately I cannot see my training back and was wondering if there is an option to recover this activity:(
Best Answer05-30-2025 16:46 - edited 05-31-2025 12:32
@Sandrabg I’m sorry, but I don’t know of any way to recover that training. It is important to start with a full battery. According to this Help article, a Versa 3 battery can last up to 12 hours with continuous GPS use. It won't be that long if your Versa 3 was one that got the firmware update for battery issues. Don't use Always On display at he same time. That uses a lot of battery. Batteries lose capacity as they age, so I'm sure that 12 hours applies to a brand new device.
Laurie | Maryland
