04-08-2022
06:17
20:05
04-08-2022
06:17
20:05
This morning I could not sync my Versa 3 to my iPhone XS. The Versa 3 does not show in Bluetooth devices. I restarted phone and Versa 3, no improvement. Uninstalled the app and reinstalled from Apple Store, no change. The Versa 3 is visible to my laptop Bluetooth, so I connected to it. However all sleep logs are missing. I can only see 'Calories' in the center, instead for "Steps" that were there before.
iPhone XS still cannot see the Versa 3 over Bluetooth, I made several more restarts, without change.
04-08-2022
10:01
13:05
04-08-2022
10:01
13:05
Hi @VictorIvanov359 - you should be able to click edit on the laptop and add/move the items around.
If you accessed the watch on the laptop it is probably linked to that device now.
Remove it from the device/turn off the laptop so it is not using Bluetooth and restart the watch.
On the phone, try
you may need to reboot the phone and watch one more time if it doesn't work.
04-08-2022
10:01
13:05
04-08-2022
10:01
13:05
On the phone, try
04-08-2022 13:45
04-08-2022 13:45
I switched off the Versa 3 completely for an hour. Also switched off my iPhone XS for half an hour. Then placed the Versa 3 to charge for a while, without switching it on. Interestingly the display lit up showing a rhomboid dotted greenish logo. I started the iPhone, and the Versa 3, and after starting the app on the phone there appeared the wizard that helps to connect a new Fitbit device. They managed to connect, I set them up step after step. It looks normal, I hope it will keep like this. Thanks a lot for the idea!
04-20-2022 03:31
04-20-2022 03:31
Many, many thanks Guy for your solution to this problem I started to encounter two days ago.
A Story
I looked everywhere on The Interwebs™ for a fix and found nothing.
This AM, I began to create a New Thread and it wasn't until I typed in the last word that Guy's answer came up.
A Suggestion to Fellow Fitbit Community Members
Understand that those who help are volunteers.
If possible, try to use the Search function for clues for a fix to your particular problem.
You'll be glad you did!
04-20-2022 03:53
04-20-2022 03:53
Thanks @walk_do_not_run appreciate your time and effort - it is a good suggestion.
Furthermore, it would seem some people merely add to a topic without reading all the relevant posts, many of which will resolve their problems.
A suggestion.
If there are a lot of posts in a thread or topic, work backwards from the bottom till you find a kind person who posted a thank you,
Often it can be in reference to a better answer than best answer, or be the best answer if none has been marked.
