06-11-2023 11:46
06-11-2023 11:46
I've just started experiencing a similar issue to other users with the Versa 3: the exercise app simply won't start. I select, it loads for a bit with the exercise icon, and then it simply goes back to the home screen.
I worked fine yesterday - no updates, etc nothing changed. All other apps currently working.
I have restarted the device and the problem persists, and I have the original clockface (ie never changed), however, I tried to change it so something else and then back to the factory normal. All of these did not fix the issue.
Any other options ? The watch is barely a year old and has been working great otherwise. Any chance at an update, or potentially another exercise app that could be used ?
Thanks
Joey
06-11-2023 20:17
06-11-2023 20:17
Hi @jomercier88 - this does happen if the operating system gets corrupted and the only way to fix it is a factory reset but before you do that sync the watch to get all the data off it and
It is a good idea to make a note of the names of any clocks or apps and any special watch or app settings you use before the reset.
There are always risks of total failure during a factory reset which can be done from the watch Settings, About Versa 3 menu.
Once you click the factory reset option don't touch the watch for 5 minutes and just wait for it to start up as it was when you got it and then in the app "Set up a Device" and replace.
