04-18-2023 03:12
04-18-2023 03:12
So I bought a versa 3 off this older lady kn mercari who was selling it because she lost her phone and couldn't get it unlocked anymore to use it. I see that plenty of other models have a factory reset option with button combinations but I can't seem to find the info for the versa 3. I tried the hold the button down wait till logo appears wait 2 seconds and hold again but it didn't work. Any help would be great thanks!
04-18-2023
07:51
16:25
04-18-2023
07:51
16:25
Hi @edora19 - it is possible to factory reset with the buttons but it can also fail catastrophically, so best to chat via the Fitbit App, click profile photo, Help & Support, Contact Customer Support, they can guide you through it.
If you have had a Fitbit before it is a good idea to note the names of any clock or apps you use in the Fitbit App Gallery tile, for installing later.
Best Answer04-19-2023 05:37
04-19-2023 05:37
Hello @edora19 It sounds like you did the reset steps in the correct order, but to review:
The Versa 3 haptic button is awkward, so you might need to try this more than once. If this doesn't work, you should contact the seller on Mercari for a refund. Items are supposed to be in working order when sold.
Laurie | Maryland
