Versa 3 first hot and now dead
My Fitbit is in use since April 1st. Yesterday after charging it, it was really hot and did not work anymore. It is completely turned off and I cannot start it anymore. Help !
1 REPLY 1
Sounds like it is faulty. If you want advice from Fitbit just to be sure, then use their direct support link.
https://myhelp.fitbit.com/s/support
If you bought it from a store, it might be quicker to return it there, especially as it sounds like you need a replacement.
