03-07-2022
08:04
20:21
03-07-2022
08:04
20:21
I have tried to reset it on and off the charger multiple times. Still frozen and stuck on clock screen. I have tried to change the clock face and still frozen. I don’t know what else to do and I am getting really frustrated with this issue. This is the second Fitbit I have had and I like to keep with this brand for all my smartwatch needs.
03-07-2022 08:33
03-07-2022 08:33
Hi @Fefanator - have you tried to double tap the screen and immediately swipe the face to the right to get to Quick Settings and disable Always On and enable wrist wake.
03-07-2022 08:39
03-07-2022 08:39
Yes I have, I can hit the side button and it will vibrate, but I can not swipe up or down or side to side. It just stays on the main clock page.
03-07-2022 08:42
03-07-2022 08:43
03-07-2022 08:43
It’s the correct time. 10:43. And it still counting steps. That part if working but I can’t swipe.
03-07-2022 08:44 - edited 03-07-2022 08:46
@Fefanator - can your restart it ? How do I restart my Fitbit device?
03-07-2022 08:45
03-07-2022 08:45
ok I will try this and let you know. Thank you.
03-07-2022 08:48
03-07-2022 08:48
@Fefanator - you will try the restart?
03-07-2022 09:21
03-07-2022 09:21
It still didn’t work.
03-07-2022 09:32
03-07-2022 09:32
Did it restart and the swiping is still not working, or did it not restart?
03-07-2022 09:46
03-07-2022 09:46
Correct. I did it a few more times and still not swiping.
03-07-2022 09:49
03-07-2022 09:49
@Fefanator - thanks, Probably best to contact Fitbit Support directly. They may be able to help you with the next step.
Also reachable via the Fitbit App, click profile photo, Help & Support, Contact Customer Support.
If it is still under warranty, 1 or 2 years depending on country law, and found faulty it may be better to take it to the shop for a new replacement, rather than accepting a refurbished replacement from Fitbit and dealing with sometimes drawn out return and shipping issues that may occur.
03-07-2022 14:16
03-07-2022 14:16
I contacted them, they said to do a factory reset and I did. Still doesn’t work…. Is anyone else having this issue? Ugh so frustrating
