11-03-2022
14:41
17:02
11-03-2022
14:41
17:02
Please help! I have a Versa 3; and for some reason, my heart rate is no longer syncing. 😞
Also, the display on face seems to have changed - How do I get face display to always show date, time, steps, heartrate and calories?
-Grace C.
11-04-2022 09:50 - edited 03-15-2024 11:55
Hi there, @GraceC.. Welcome to the Community Forums. Thanks for the details provided in your post about the issues with your Versa 3. I understand how you must be feeling.
Is the heart rate the only data that won't sync to your Fitbit app? If so, to address both issues, heart rate and clock face, please restart your Fitbit device as suggested here How do I restart my Fitbit device? If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
Hope that helps.
11-07-2022 17:32
11-07-2022 17:32
11-08-2022 03:08 - edited 11-20-2023 03:45
@GraceC. I appreciate you had followed the tips and recommendations provided above.
To better assist you, may I know if your Versa 3 does vibrate when trying to perform the restart or whenever you connect it to the charger? If so, as our last resort, I suggest to perform a factory reset by following these steps:
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account, your applications, alarms, etc.
Hope this does the trick.
11-08-2022 18:31
11-08-2022 18:31
11-10-2022 06:39
11-10-2022 06:39
@GraceC. Sure thing!
I'll be around if you need further assistance. 🙂
11-10-2022 07:52
11-10-2022 07:52
11-14-2022 06:31 - edited 11-20-2023 03:45
@GraceC. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
11-14-2022 15:46
11-14-2022 15:46
