04-22-2022
11:34
20:02
04-22-2022
11:34
20:02
Been swimming on a regular basis, pool is 33.3 yards. I am doing 50 lengths. Fitbit states im doing 1394 yards???
50 x 33.3=1665 yards a discrepancy of 271 Yards
can anyone explain, or how do i adjust my fitbit to monitor correct distance?
04-27-2022 07:44 - edited 01-05-2024 13:37
Hi there, @Coops_1960. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your swim distance.
Have you checked the units of measurement? To start the pool length is set in meters. To change the unit of measurement to yards for swims, see How do I change the units of measurement in my Fitbit account?
Hope this helps.
Hope this helps.
05-25-2022 12:15
05-25-2022 12:15
Hi ya thanks for help, so far i have changed the distance to metres but it is still measuring the pool at 25m its actually 30.4 how do i change that
06-12-2022 11:13
06-12-2022 11:13
Hi MarreFitBit, thanks for help. Unfortunately my versa 3 measures distance of a 25m metre pool, How do i change that?
06-18-2022 05:26 - edited 01-05-2024 13:36
Hi there, @Coops_1960. Thanks for stopping by in the Community Forums.
You should be able to set the pool length for your Fitbit device by following the steps you mentioned above:
If after selecting Swim you don't see the Pool Length option, please attach an image of what you see for further investigation.
