Versa 3 is lighting up during my sleep
ANSWERED
I have display set to button only and everytime I put my arm under my pillow or cross my arms it turns this never happened with my first versa3, since I recently bought this new one it happens.  It should only turn on when I press button or double tap screen.
1 BEST ANSWER
Accepted Solutions
Hi there, @tdebol1. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 3. I understand where your concern is coming.
To avoid this from happening, I'd recommend using the sleep mode on your Versa 3. When the sleep mode setting is on:
  • Notifications, goal celebrations, and reminders to move are muted.
  • The screen's brightness is set to dim.
  • The Always-On Display clock face is turned off.
  • The screen stays dark when you turn your wrist.
  • The sleep mode icon illuminates in the quick settings.
Sleep mode turns off automatically when you set a sleep schedule. To set a schedule:
  1. Open the Settings app and tap Quiet modes.
  2. Under Sleep mode, tap Schedule mode Off-hours.
  3. Tap the start or stop time to adjust when the mode turns on and off. Swipe up or down to change the time, and tap the time to select it. Sleep mode automatically turns off at the time you schedule, even if you manually turned it on.
You can't turn on do not disturb and sleep mode at the same time. For more information, see How do I navigate my Fitbit device?
1 REPLY 1
