02-17-2022
17:19
20:28
02-17-2022
17:19
20:28
Hey, I got the versa 3 for Christmas. The charger doesn’t seem to be charging this time. Has anyone had a problem with theirs?
02-17-2022 23:24
02-17-2022 23:24
Hi @Cooki60394 - it is a fairly common problem, it can often be from a mixture of needing cleaning or faulty charge cables, see How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
Best Answer02-18-2022 06:08 - edited 11-12-2023 06:13
Hi there, @Cooki60394. Welcome to the Community Forums.
If you haven't done so yet, please check if the pins on the device or charging cable are dirty. For more information on how to do so, see Why isn't my Fitbit device's battery charging?
Hope that helps.
Best Answer02-18-2022 07:40
02-18-2022 07:40
10:01
18:27
02-18-2022
10:01
18:27
@Cooki60394 - did you check the charge cable fully and the 4 contacts. If the watch isn't charging it will appear dead.
If you don't succeed as it's still under warranty probably best to contact Fitbit Support directly. They may be able to send you are replacement charge cable or you can get them online.
Also reachable via the Fitbit App, click profile photo, Help & Support, Contact Customer Support.
Make sure to keep your watch though as it's probably not faulty just flat battery.
Best Answer07-21-2022 21:58
07-21-2022 21:58
I bought a couple copy chargers from local store plus a watch charger type item and all work fine. In my case the pins on the original fitbit charger all seem to be parallel to the charger. So theres no connection made with the watch.
Best Answer07-21-2022 22:06
