07-19-2024
03:20
11:42
07-19-2024
03:20
11:42
I have noticed for the past week or so my Fitbit Versa 3 has calculated 0km everyday when usually even on a lazier day it will clock a few km’s. I’m not sure why it’s stopped working but I’d love to know how to fix it
07-24-2024 14:01
07-24-2024 14:01
Hi everybody! Welcome to the community! Thank you for your messages and efforts.
Our team is aware of the situation and is working on a solution to it.
Many users have now confirmed that they were able to fix it by entering the stride length themselves. It's worth a try until our team has worked on the solution.
You can find instructions for this here:Can I change my stride length in my Fitbit account?
Please follow this thread where all updates will be posted. Distance appears as 0 after sync
Best Answer07-19-2024 04:31 - edited 07-19-2024 04:31
Hello @Nico.29 and welcome to the Community. It looks like there is a bug in the automatic stride length calculation. Please try the following workaround. Tap on your profile picture/gear icon in the upper right of your app, then Exercise. Look for the Stride length option. Tap on it and toggle Set Automatically off.
Laurie | Maryland
Best Answer07-19-2024 14:11
07-19-2024 14:11
53 weeks and 7 days after purchase, my versa 3 stopped tracking distance. 23,000 steps, 0 miles!!!
Google acknowledged it's broken, want me to post it back to US for 'refurbishment '. When I purchased it there was data on it prior to my owning it. Presumably it was a refurbished one. It had lower heart rate and mileage. Fitbit had such a good name. I'm disappointed to see that Google doesn't believe in good honest customer service, where the customer is treated well. A smartwatch that fails 11 days out of guarantee??? Post from UK to US for 'refurbishment '? Really?
Best Answer07-19-2024 22:21
07-19-2024 22:21
Thanks to 'Laurie, Maryland', my Versa 3 now tracks distance again. Unbeknownst to me, I should have disabled stride (which I hadn't actually set).
The Fitbit (Google) support were EXCELLENT, B U T they are limited to a set protoco which they can't veer from, they have no authority. Also, I didnt speak their language, but they could speak English. Nil points to me, support group.1.
07-22-2024 09:56
07-22-2024 09:56
My wife and I both own a Versa 3 and within a few days of each other both have stopped recording distance in normal use. They still record distance on the Exercise App. Google/Fitbit have not been able to resolve this. We’ve undertaken various trouble shooting measures including a factory reset. Google/Fitbit say there is nothing more they can do. Both are out of warranty. It seems very strange that it has happened to both watches so close together. They deny there is any issue with software etc and that no other watches are affected.
Best Answer07-22-2024 10:13
07-22-2024 10:13
Best Answer07-22-2024 11:42
07-22-2024 11:42
Thanks. This is all very odd. I’ve had a look at Stride length on by our Apps. They are set up as Automatic and show a stride length for Running but as with you nil for Walk ?? The odd thing this must have occurred before the factory reset. I entered a manual figure. I will test. Why though is it not identifying one automatically. I will do some more testing. Thanks again.
Best Answer07-22-2024 11:50
07-22-2024 11:50
Best Answer07-22-2024 13:50
07-22-2024 13:50
Thanks. The watch now seems to be calculating distance after cancelling the Automatic on Stride. It is still perplexing how this issue arose on two watches after 2+ years of working normally. I wonder if a recent update has caused this. The issue arose before the factory reset. Fingers crossed.
Best Answer07-23-2024 00:54
07-23-2024 00:54
Best Answer07-24-2024 14:01
07-24-2024 14:01
