07-16-2023
12:29
03:50
07-16-2023
12:29
03:50
Versa 3 is not counting floors correctly again. Is there any solution to this besides reseting and downloading the software, AGAIN?
07-16-2023 21:20
07-16-2023 21:52
07-16-2023 21:52
07-16-2023 22:17
07-16-2023 22:17
@RogerF - see a detailed floor count explanation here How does my Fitbit device calculate my daily activity?
As you experienced floor count problems on other devices it may be more a difference of expectation vs realisation.
The minute pressure sensor can be affected by cleaning so check the watch is clean and the holes are not obstructed but don't poke in the holes as that can do damage.
The algorithm that detects steps has to match elevation change, so for instance holding the bannisters while going upstairs or taking 2 steps at a time, or going too quickly or slowly can affect registration.
You can only expect an approximation of floor count which incidentally does not have any effect on other measurements so is merely informational.
If you want to investigate the pressure sensor try the SimpleFloors app which was made for an older firmware but you may find it useful.
07-16-2023 22:22
07-16-2023 22:22
