09-09-2022
18:19
17:12
09-09-2022
18:19
17:12
Hi,
My Versa 3 is not tracking sleep, I have been wearing watch for 4 nights. The first night it track 4hrs when I slept about 6.5. the next 3 it hasn't picked up anything. I am recording a HR and synching watch but nothing is being transferred to app. Very frustrating as I have to record sleep for my shiftwork.
09-10-2022 06:37 - edited 07-25-2023 07:22
Hi there, @PaulGill. Welcome to the Community Forums. Thanks for the details provided in your post about the inconvenience with your Versa 3. I understand where your concern is coming from and how you must be feeling. @Guy_ Thanks for your help!
I recommend considering the following in order to get sleep stages:
For more information, see What should I know about Fitbit sleep stages?
09-09-2022 21:37
09-09-2022 21:59
09-09-2022 21:59
09-09-2022
22:05
07:01
09-09-2022
22:05
07:01
@PaulGill - sync the watch and try a full Shutdown from the watch Settings menu. Wait at least 10 seconds before placing on the charger to restart it and charge it. See if that helps tonight.
If you have tattoos if may be a problem, check how well the heart rate is working at rest, and consider changing arms at night to where there are no tattoos.
You can also set a sleep schedule in the watch settings and change the sleep sensitivity in your web account dashboard. That may help also.
09-09-2022 22:14
09-09-2022 22:14
01-02-2023 05:56
01-02-2023 05:56
I have tried everything to get my sleep data working again. Nothing has worked. I will be discontinuing the premium upgrade and won't be buying a Fitbit again. I have seen a plethora of complaints about this. What is Fitbit doing about it? Why do companies change things which are working correctly instead of actually fixing things which aren't. This all started when you updated the sleep app recently. I like the graphics better on previous one. Completely frustrated 😠 and have spent time I will not get back going through all these worthless steps to fix it.
06-10-2023 10:25
06-10-2023 10:25
Versa 3 is not recording sleep since I baught it
need to be replaced
thank you
beeram Jaikaran
06-10-2023 10:26
06-10-2023 10:26
I tried every thing to get the sleep data working however never work
thank you
06-10-2023 10:28
06-10-2023 10:28
Hi @joanjaikaram - is it tracking heart rate properly, if you have tattoos it may not be working for that and nor sleep.
06-10-2023 10:37
06-10-2023 10:37
