Versa 3 is not tracking my sleep times accurately
ANSWERED
Sleep tracker is not properly tracking my sleep. It says, I slept only 2 hrs, when have had 5hrs, 6 or more hrs!
1 BEST ANSWER
Accepted Solutions
Hi there, @Janetk1. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your sleep data.
As a first approached, I'd recommend to sync your Versa 3 to the app after waking up. This will help to make sure that all your data is sync properly.
Also, note that your time asleep is calculated by subtracting your time spent awake and restless from your overall tracked sleep time. For example, if you slept 8 hours but woke up 2 times for 15 minutes each, your time asleep would be 7 hr 30 min.
To learn more about your time asleep in sleep stages, see What should I know about Fitbit sleep stages?
Edit or delete sleep logs in the Fitbit app. For instructions, see How do I add, edit, or delete Fitbit data and activities?
Hope this helps.
1 REPLY 1
Hope this helps.
