06-02-2023
02:53
05:33
06-02-2023
02:53
05:33
Hi . when i wake , if i don't sync my versa 3 straight away with my mobile it still thinks im asleep even tho i get up make breakfast etc ,if it takes me an hour and i sync my watch it will say i have just woken up , is this a fault or is it something in my settings ,any help will be appreciated , thanks 🙂
06-02-2023 05:35
06-02-2023 05:35
Hi there, @spooky2000. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the inconvenience with your Versa 3.
This may happen, so as a first approach, I'd recommend to sync your Fitbit device to the app after waking up. This will help to make sure that all your data is sync properly. Note you can always edit your sleep logs in the Fitbit app. For instructions, see How do I add, edit, or delete Fitbit data and activities?
On a side note, keep in mind that your time asleep is calculated by subtracting your time spent awake and restless from your overall tracked sleep time. For example, if you slept 8 hours but woke up 2 times for 15 minutes each, your time asleep would be 7 hr 30 min.
To learn more about your time asleep in sleep stages, see What should I know about Fitbit sleep stages?
Best Answer06-02-2023 08:20
06-02-2023 08:20
why has my subject header been changed ???
