12-30-2020
05:12
20:47
12-30-2020
05:12
20:47
01-03-2021 10:49
01-03-2021 10:49
Hi Becky
Iv just got a versa 3. & it’s different to my versa. Mine wasn’t vibrating when I reached my goal. But it was vibrating for timer & alarms. I turned the volume up. Swipe to the right turn it up as far as it will go. Hope this helps
Best Answer01-01-2021 13:20 - edited 08-15-2025 08:56
Hi there @Becky70, welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 3 before reaching out.
Please note that your Versa 3 also alerts you at various times, including if you set an alarm, when you hit your step goal, or if you haven’t met your hourly activity goal.
If your watch isn't alerting you:
If you correctly set the alarm or aren’t receiving other alerts, test your device’s vibration motor:
Let me know how it goes.
01-03-2021 01:45
01-03-2021 01:45
Hi Marre
Many thanks for your reply. Unfortunately, the things you've recommended I've already tried. My watch vibrates when alarm or timer is set, just not when it reaches 10,000 steps. Do not disturb etc is not on. I'm at a loss.
Is there anything else you think I could look at?
Many thanks in advance
Becky
Best Answer01-03-2021 10:49
01-03-2021 10:49
Hi Becky
Best Answer01-04-2021 00:58
01-04-2021 00:58
Best Answer10-28-2022 20:59
10-28-2022 20:59
Hi can I ask if this worked for you, I have the same issue with it not vibrating when I reach 10000 steps
thanks Evie
Best Answer10-28-2022 23:55
10-28-2022 23:55
Hi Evie,
I think it did. I'm sorry it was a long time ago and I no longer have a fitbit as I went over to a Samsung watch 4
I hope it works for you
