10-04-2022
15:46
17:09
10-04-2022
15:46
17:09
How do you fix the time on your watch it’s like four hours ahead
10-04-2022 17:49
10-04-2022 17:49
Hi @Cindytee the time comes from the device you use to sync and it can't be manually set. Try restarting your Versa 3 and syncing a few times.
Best Answer10-06-2022 18:38
10-06-2022 18:38
I'm having the same issue. Flew from Detroit to Las Vegas and it hasn't corrected itself.
I've shut it down and restarted it multiple times. Synced it with the phone and app multiple times. Nothing is helping.
Best Answer10-06-2022 19:04
10-06-2022 19:04
After making my first post earlier, I accessed my profile thru the website here... Instead of using the app. There was an option to select my time zone, which was incorrect. Once I changed my time zone here, it corrected my watch.
Good luck!
