01-25-2021
11:42
20:50
01-25-2021
11:42
20:50
My Versa 3 is new a few months old and yesterday during a walk on a hot day just rebooted and is stuck in a reboot loop, it shows the logo and then screen cuts and 10 seconds later the logo is on again and the same loop continues. I have tried resetting the device by holding down the haptic button for 20 seconds, during that time it just goes through the same reboot loop, with no change. To be honest for years I have used Fitbit and have never had any issues until now, it is very disappointing.
Has anyone had a similar issue?
09-26-2022 08:31
09-26-2022 08:31
03-07-2023 04:41
03-07-2023 04:41
I've got the same issue, it started yesterday. The last synch was yesterday morning, I did not notice it was not synching until last night. Have tried the suggestion to push the button multiple times until the watch vibrates and then hold for 20 seconds. This just starts of another cycle of continual rebootings. The watch is now showing 0%, I might wait until it drains out the power to even show the 0%, and then try recharging it.
Seems like there should be a way to refresh or reload the system for instances like this, if they are caused by an incomplete system update.
03-07-2023 06:41
03-07-2023 06:41
The only way I found to fix it was to reset it back to the factory default & delete all user info then go through the whole pairing & setup process. Problem is it's been over a year or so since I had that issue and I've forgotten how I was able to get to it to that particular setting. I want to say it's by holding the button(s) on the side for 20 seconds or longer.
