07-04-2022
05:45
17:50
07-04-2022
05:45
17:50
My versa 3 screen is stuck on the Fitbit logo, won’t charge or do anything….please help
07-04-2022 05:49
07-04-2022 05:49
Hi there, @michellesimiste. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 3.
Please note the issue you're having comes from performing a factory reset without first unpairing your Fitbit device from your Fitbit account and phone's Bluetooth settings. With that being said, I suggest following the steps below in the order listed:
If you can't get started with your Versa 3, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Hope that helps.
07-04-2022 05:49
07-04-2022 05:49
Hope that helps.
07-04-2022 05:55
07-04-2022 05:55
Can you please advise how to force quit the app?
07-04-2022 06:13
07-04-2022 06:13
@michellesimiste You can find more information at https://support.apple.com/en-us/HT201330
See you around.
07-04-2022 06:47
07-04-2022 06:47
None of that has worked, the watch is no different, it’s the watch that needs fixing not the app on my phone, please advise next step
07-04-2022 06:49 - edited 11-16-2023 04:17
@michellesimiste I appreciate you had followed the tips and recommendations provided above.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
