11-01-2022
01:23
17:02
11-01-2022
01:23
17:02
Hello
My Versa 3 randomly reset itself a few days ago. It’s set itself as dim brightness, turned off ‘motion and button’, and turned on BOTH ‘do not disturb’ and ‘sleep mode’ - yes, this should not be possible. Do Not Disturb’ will not turn off and gives a message ‘locked for sleep mode. Turn off sleep mode to change this setting’. Sleep mode will not turn off and gives a message ‘locked for Do Not Disturb. Turn off Do Not Disturb to change this setting.
I have reset the Fitbit 5 times (which is difficult, it keeps going to alarm settings and yes, I know to fully cover the button with my thumb). In between resets, I’ve removed the Fitbit from the app and set it up again. I’ve deleted the app completely, reinstalled it and re linked the Fitbit. I’ve done all that with hard reboots of the iPad in between. I’ve done all this again.
I’ve easily wasted 6 hours on this and am massively frustrated. I’ve had fitbits since 2016. I got the Versa after the Fitbit charge stuck on ‘dim’ and clearly had a wide ranging issue. It looks suspiciously like yet another firmware upgrade gone wrong that wasn’t tested properly before it was released. Again.
I’m now stuck with quite an expensive watch that barely works. Again
I rarely get so annoyed by things that are relatively trivial, but I’m on Google looking at apple watches and Garmin devices after being a loyal customer for many years.
Please sort this out!
11-01-2022 11:31
11-01-2022 11:31
@Ferny Thanks for the details provided in your last post.
As our last resort, I suggest performing a factory reset on your Versa 3 by following the steps below:
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account, your applications, alarms, etc.
Let me know how it goes.
11-01-2022 09:52
11-01-2022 09:52
Hi there, @Ferny. Thanks for stopping by in the Community Forums and trying to troubleshoot the issue with your Versa 3 before reaching out. We‘re taking your comments and sentiments in regards to our products into consideration.
As per the description of your post, it seems like you might have a sleep schedule. Sleep mode turns off automatically when you set a sleep schedule. To set a schedule:
You can't turn on do not disturb and sleep mode at the same time.
Hope this helps.
11-01-2022 11:05
11-01-2022 11:05
11-01-2022 11:31
11-01-2022 11:31
11-01-2022 11:53
11-01-2022 11:53
11-03-2022 12:56
11-03-2022 12:56
@Ferny Thanks for trying the steps I recommended above.
Please let's try a second method for the factory reset, so on your Fitbit device, open the Settings app > About > Factory Reset.
As recommended above, please make sure to sync your Versa 3 before performing the factory reset.
11-03-2022 15:16
11-03-2022 15:16
11-03-2022 15:41
11-03-2022 15:41
@Ferny I'm glad to hear that worked!
We're constantly striving to improve Fitbit products and services, and we appreciate all of the input we receive from our customers. Thanks for your feedback and for participating in our community!
01-30-2023 12:29
01-30-2023 12:29
I am having this same issue. I have my Off hours set from 10 pm to 7 am and the sleep mode is still on during when it is not those hours. I have reset my fit bit and changed the clock and like I've seen other posts say to do. And it still doesn't work.
01-30-2023 12:34
01-30-2023 12:34
