08-15-2021
14:31
20:47
08-15-2021
14:31
20:47
I had pushed the swimming timer about 3 hours ago and haven't been able to get it off. There is a lock button by it nothing will work besides my Google Assistant.
08-16-2021 07:27 - edited 07-20-2023 05:23
Hi there, @Jveg2002 @Kylie21. Welcome to the Community Forums. Thanks for the details provided in your post about the inconvenience with your Versa 3. I understand where your concern is coming from.
Water lock turns on automatically when you start a swim in the Exercise app. Try a double tap of the button to turn off water lock. For more information, see Can I swim or shower with my Fitbit device?
08-15-2021 15:07
08-15-2021 15:07
I just used the swim mode for the first time . Mine is also stuck and I'm wondering how to get it out without having to reset it
10-12-2021 05:58
10-12-2021 05:58
worked for me also
10-12-2021 07:22 - edited 03-09-2024 05:49
@thebear48 Amazing! 🙂 I'm glad to hear about that, thanks for confirming that the steps provided above did work.
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
Happy stepping!
02-25-2022 04:25
02-25-2022 04:25
Doesn't work for me
02-25-2022 07:53
02-25-2022 07:53
Double tap to stop water lock Doesn’t work for me either
08-14-2022 13:43
08-14-2022 13:43
On my watch, there is no button so I can't do it.
08-14-2022 14:34
08-14-2022 14:34
Hello @Joannazironggao and welcome to the Community. The Versa 3 doesn't have a button that sticks out. Run your finger along the left side of the screen. You will feel an indentation. It's called a haptic button. Press it and you'll feel a vibration. You need to press it twice and feel that vibration twice. The timing is important. It doesn't always work on the first try.
Laurie | Maryland
08-14-2022 16:19
08-14-2022 16:19
Try holding it. That's how I do it.
08-27-2022 15:20
08-27-2022 15:20
Doesn’t work for me. It’s still on swim mode
08-28-2022 05:10
08-28-2022 05:10
@missyportela The timing is very important. There seems to be a sweet spot in the timing of the two presses. Make sure you feel the vibration. Once or twice it took me 5 times to end it.
Laurie | Maryland
01-03-2023 02:06
01-03-2023 02:06
I have the same issue but even when I double tap the button it doesn't turn off. Is there another way? Am I missing something? Only way I can get it off is to reset it meaning I lose all my swim data.
01-04-2023 05:31
01-04-2023 05:31
Hello @Mitchjames and welcome to the Community. The only way to turn off the water lock without losing data is to double press the button. Like I wrote in my other post, it seems like the timing needs to be just right.
Laurie | Maryland
02-06-2023 05:38
02-06-2023 05:38
After almost an hour of tapping the screen, I came across your suggestion and it worked after a couple of tries, thanks 🙂 x
