Versa 3 is tracking my floors inaccurately
Looking at the past it has been over 18 months.
Has there been any update on an inaccurate floor count with the Vera 3.
I purchased mine in Jan 2022. In the past few months it seems to have gone wonky.
Thanks for any update or suggestions to fix
1 REPLY 1
Hi @Rlummerding - have a look in the forums, this is a general issue which often occurs around the same time as a firmware update.
If you are curious try the SimpleFloors app for a test to see how your pressure sensor is working, it won't fix it but will give you some indication that your watch is fine and possibly capable of getting a more accurate floor count.
