11-04-2022
23:32
17:02
11-04-2022
23:32
17:02
I've been wearing a Fitbit for a couple years and am happy with it.
Over the last two months, I've seen an increase in Active Zone Minutes of 200% with no increase in exertion. As an example, last week I got over 1400 zone minutes, 321 just today. on a mostly sedentary day.
Is this a problem I should be concerned about.
TIA
11-05-2022 06:00 - edited 07-29-2023 03:58
Hi there, @240Gordy. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 3.
As a first approach, I recommend to restart your Fitbit device and to make sure you're following these tips to properly wear your Versa 3. After this, continue monitoring its functionality.
On a side note, bear in mind that active zone minutes are earned based on your heart rate data. With that being said, bear in mind that heart-rate tracking can be affected by several factors including air temperature and device location on your arm For more information, see What factors can affect my heart-rate reading on my Fitbit device?
07-28-2023 14:21
07-28-2023 14:21
Versa 3. I've tried restarting. I've checked the wristband. While exercising the watch showed 12 zone minutes but when I synched, it jumped to 90 minutes which is not correct. My heartbeat plot shows about 12 minutes of fat burn and NO cardio.
Why is it doing this? How can it be corrected?
07-28-2023 15:48
07-28-2023 15:48
