03-07-2022
18:02
20:21
03-07-2022
18:02
20:21
Starting about 2 weeks ago my Versa 3 starting counting a crazy amount of floors. My average is about 5 to 10 floors. Its progressively getting worse (higher floor count day by day) Yesterday it counted 43 and tonight I'm up to 67 floors! It counts at least 5 floors while I'm sleeping! I called customer service and the lady I could hardly understand didnt offer any help. Said just restart it and check app for updates. I had already done that. Any plans to fix this issue? I've only had my versa 3 about a month.
03-08-2022 02:25
03-08-2022 02:25
Hi @strayerd - we would all like this issue fixed, you will find many other same reports in the forum.
If you are interested in how your watch pressure sensor is behaving or whether you can get a more accurate floor count, you can verify you don't have a watch problem by using the SimpleFloors app.
The App shows how your watch is affected by environmental issues such as, going room to room, upstairs/downstairs, inside to outside, changes in temperature, etc.
This App is only meant for checking purposes as it uses the battery a lot, but at least it will give you an idea if your watch is fine or if it is some other issue which seems to be the case.
Best Answer03-08-2022 07:06
03-08-2022 07:06
Hi there, @strayerd. Welcome to the Community Forums. We‘re taking your comments and sentiments in regards to our products and services into consideration.
If the recommendations provided by our Support Team didn't help, please feel free to contact them back so they can continue assisting you.
See you around.
Best Answer03-08-2022 14:43
03-08-2022 14:43
This problem has been known since the device was released. Fitbit does not care and does nothing and then you warranty runs out. Not a good product or company.
