03-27-2022
08:20
20:14
03-27-2022
08:20
20:14
Hello,
When waking up my fitbit counted 35,000 steps while sleeping. After reading I have confirmed my height is correct, wearing on my non dominant hand, & the app the set to that. My phone is on the nightstand & the steps on that pedometer still says 0. I'm ok with having 100 steps counted on average when waking, but don't understand how it's counting 35,000. Any suggestions would be helpful.
03-28-2022 10:22 - edited 12-27-2023 04:29
Hi there, @LoLoZ. Welcome to the Community Forums. Thanks for the details provided in your post and for making sure your height is set correctly. I understand where your concern is coming from.
I'm wondering if you're using another app connected to your Fitbit account that will add more steps? Mobiletrack maybe? Low-power step sensors inside your phone track your steps and send the data to the Fitbit app. We recommend using MobileTrack if you forget your Fitbit device at home.
Note that adding more than one Fitbit device to your account gives you the convenience of switching between devices while still seeing a holistic view of your daily activity on your dashboard.
If you want to negate the steps tracked while you were sleeping, see How do I add, edit, or delete Fitbit data and activities?
As a friendly reminder, please note that Fitbit devices have a finely-tuned algorithm for step counting. The algorithm is designed to look for intensity and motion patterns that are most indicative of people walking and running. When working at a desk, cooking, or performing other activities with arm movements, a device on your wrist may add some steps. When you’re doing activities that involve arm movement—such as working or cooking—you often walk a few steps in-between stationary periods as well, so the device tries to give you credit for those steps. For most customers, the number of extra steps added by arm-based movement isn’t significant when compared to your overall stats. For more information, see How does my Fitbit device calculate my daily activity?
Hope that helps.
Best Answer03-28-2022 10:22 - edited 12-27-2023 04:29
Hope that helps.
