07-18-2021
06:50
20:47
07-18-2021
06:50
20:47
Hello
My fit bit versa 3 doesn't work as it should. There is no synchronization, notification is simply nothing.
Only occasionally
Help me?
09-14-2021 17:19
09-14-2021 17:19
Hi @Petu6525,
You need to download and sign into the Fitbit app on your phone. Turn your BT on and you should be fine. Pull down on the screen to sync it manually. Also, you can use the same credentials to log in on your app as you do for the website.
You will need to set up your Versa 3 on the app. Once you log in, you should see an icon in the top left corner. Tap it, these are your Account Settings. Find "Set Up A New Device" and select "Versa 3". From there, all you need to do is follow the prompts.
one cruise ship at a time!01-04-2022 16:06
01-04-2022 16:06
Ok I did the device setup on my phone and all seems to be working. Time will tell
