08-20-2021
01:47
20:47
08-20-2021
01:47
20:47
Had my versa 3 just under 4 weeks. When it auto tracks exercise it transfers the info over. When I tell it I’m doing an exercise it transfers over the active minutes etc but does not log it as an exercise.
I have tried the following from the help guide
phone software is up to date
Fitbit software is up to date
App is the latest version
restarting my iPhone
restarting the Fitbit. It works straight after but I have to keep doing this.
I have removed the Fitbit from my account deleted the app and re added as if knew. It works but a week later I’m back in the same position.
how do I fix this? I don’t want to or have the time after exercise to reboot everything to get all my info transferred. I need to know so I can calculate my insulin and food needs.
Does this go back to the shop?
08-21-2021
14:48
16:18
08-21-2021
14:48
16:18
@Ermintrude775 Welcome back to the Fitbit Community.
Thanks for the troubleshooting performed prior to posting and the details mentioned. I see where your disappointment is coming from.
I'd like you to confirm that this procedure is followed to track your workouts using the exercise app on your Versa 3:
End. Your workout summary appears
Take into consideration that once an activity has been tracked, there's no need to manually log another one as the info will be overridden.
Hope this helps.
Best Answer08-27-2022 15:39
08-27-2022 15:39
I, too, am having this problem, and have followed all the above steps. Has there been any additional info regarding a solution?
